17hp FC540V single cylinder Kawasaki on a JD 325. Bought the mower, did some general maintenance along with a lot of carb work. I've had the head off, cleaned the carbon off the piston head and valves, wasn't too bad. Cylinder was nice and smooth. Metal head gasket looked fine so i did not replace. No signs of any leaks.
Mowed with it yesterday for a little more than an hour, ran great, no problems at all. No smoke at all. Started it today and it smoked A LOT. That cleared out completely in about a minute. Mowed for about 30 minutes when suddenly a LARGE puff of blue smoke, obviously oil burning. It was so bad I was waiting for the head gasket to go but it didn't. It blew the smoke out for about two seconds then stopped. It started repeating that every 30 seconds to one minute. Still ran just fine but when it blew out smoke it was a lot of smoke. No noticeable loss of power.
So where should I start? Does this sound like a head gasket? Rings? Something else?
