I have a zero turn cub cadet mower with a 23 hp engine. It will run for a while then the fuel filter runs empty. Replaced the fuel pump, filter, line from gass tank to the carb, the air filter, spark plugs. I have removed the tank and cleaned it. The problem started this summer when it was hot when I was mowing. Now it happens warm or cold outside.
Any thoughts? Fuel shutoff soelenoid?
