- Nov 29, 2014
- 24,995
Either it is not getting any fuel or not getting any spark.
No fuel will be the cut off solenoid under the carb.
Hold it with your fingers and it should click when you turn the mower on & off, no need to crank.
If it s a no spark situation tht will most likely be because one of the safety switches is not working.
You will need some tools to test these, a minimum will be a test lamp.
