jj50cal``
- Aug 27, 2021
- 1
- 2
hi folks, my Z726X starts easily, and runs great for about 30 minutes. then act like it is running out of fuel. but it's full, checked and changed fuel filter, checked, cleaned fuel pump, then replaced said pump, replaced all fuel lines. after it sits and cools off for about 20 minutes, you can get another 10 minutes of run time. if you let it cool down till cold, you get another 30 minutes. air filters are clean and new also.i even had an extra set of coils O.E.M. coils checked good, but swapped out anyway since they were availible, and no difference. HELP! i have too much yard to mow in 30 min. increments.
