- Dec 7, 2022
- 2,237
If the mower won’t go up a hill and is making a grinding noise, it is doubtful changing the oil will help with transaxle.Contacted TuffTorq to see what I needed (exactly) to change the oil and filter. They replied the filter is NOT a servicable item and all I needed was drain plug seals and fluid. In the mean time, on a real hot day, the mower refused to go up a hill with the blades engaged and made a grinding noise, but was fine when not under the stain of mowing. I'm hoping changing the oil does the trick but the seals are on back-order.
