K66 fluid change cost
Oldaarpy
In 2015 I bought a new Husqvarna GTXLSi with the K66 locker on it and the owners manual claimed no service required. I've had great luck with this machine, mowing and plowing snow, except for the so called smart switch! But it has started slowing down going up steep hills. I'd like to get the oil and filter changed in it (at 675 hrs I'm sure it's WAY overdo from what I've read) but I'm not real mechanically inclined. At 75 yrs old I'm on a fixed budget so I'm concerned about service costs. At $100 an hours, and no other problems, can someone give me a 'ball park' figure on what the bill would be. Should I attempt to do this myself?
Tiger Small Engine
The Tuff Torq K66 is a much better transaxle than say the K46. A hundred dollars an hour for shop labor is average in many cases. You are paying experience, overhead, tools, etc. That is book time not actual work time.
Sometimes on transaxles you can only siphon out some of the oil and not change/clean the filter. Sometimes to do the job right, you have to remove transaxle from mower and turn upside down to get all oil out, still not cleaning filter.
You will find most shops will not work on transaxles. Only remove and replace as needed. Won’t comment on your fixed budget at 75 years old, because I will get in trouble.
Tiger you should look up the K66 as you would see a drain plug that is about 1-1/2" to 2" in diameter. Apparently you are just guessing at what needs to done and being too lazy to even look up the transaxle IPL on the Tuff Torq website.
Just can't change the filter without pulling the transaxle on early versions but later versions it is just a easily changed cartridge. With the number of hours if the drive belt and v-idlers haven't been changed recently it could just be a slipping drive belt.
Actually model and serial numbers are needed for proper IPL look up as to which filter would be used. Hopefully it is the cartridge type as in the left image.
It will require SAE 5w15 synthetic oil. And that plug should have a 3/8 square hole for a ratchet to fit. Careful remove that plug as that hole can be stripped out. Also all the dirt must be from the plug and surrounding area.
And if a shop not willing to do this oil change they are just plain damn lazy. It should be an hour labor plus the oil and filter if it is the cartridge type; longer if the other deep inside the transaxle type filter. But as said the filter don't have to change all the time just depends how bad the oil looks like. IF the shop are the least bit reasonable they will have a senior citizen discount like mine. I give the 65+ group a ten percent discount on repairs. Which here is basically more than just knocking off the sales tax.
Oldaarpy
Thanks for the replies. I changed the drive belt this year but the V-idlers have never been changed. Suppose to rain all day so might be a good time to check for those plugs.
Oldaarpy
Some of these tractors have three idlers and some have two. Mine has three and I'm assuming only one is a V-idler? Clutching idler? They all look good but I'll change whatever I should. The gas tank sits over the tranny so I'd bet it's a bear to even add oil.
Tiger Small Engine
View attachment 69382 orView attachment 69383
Thanks for being upbeat and positive as always. I did not look up the K66 on the drain plug, however was aware some units have plugs. Not wanting to work on hydro transaxles does not make a shop owner/operator lazy, it shows how years of working alone makes a smart person more selective on repairs.
In the words of Clint Eastwood, “A good man knows his limitations.”
The skills of customer service and how to treat and talk with people are often just as valuable as being able to repair something.
But around here I see so many local shops just taking advantage of the customers it isn't funny. Sorta like one a couple years ago. They told the customer he need a $4000 engine replacement. Good thing the customer decided to get a second opinion instead going with dealer suggestion. It turn to be a simple head gasket replacement. All of $300 in my shop do some other work that was needed at the same time.
Now I do have a K46 with very weak reverse and it quickly goes downhill when the engine is not running. Needing new center section replacement. Since I am in the Tuff Torq main distributor it cost only a 1/8 more to install a new unit. Considering how rough the customer is on the mower (cutting 10 acres per week) a new unit is his best option in this case. I can just rebuild the old unit for someone that is not as a rough user.
The 7A646084101 including oil lists for $790 plus an hour labor and the repair kit lists for $463.35, $47 for oil, plus my labor. The amount time depend how much cleaning got to be done. So it is just up to customer which way to go. Other words how quickly he needs the mower back. New unit is an one day turn around, rebuilt a few extra days. Actually more profit in the rebuilding but less time to install new unit. Both ways he get a 90 day warranty.
The right now is how much is the shipping. Salesman only gave me a guess price on shipping and his company does this shipping every day. I told to get back to me with a firm price. I don't want to get burned like last year when he told me $40-$50 to ship a short block, I quoted the customer his cost, and then I got slapped with a $200 freight bill after I done billed the customer. Always nice end up losing money on a sale because of a stupid salesman.
By the way I have work alone since 1979 on equipment, no one else was there to depend on for help. 16 yrs for the other man and still had do it all myself from actual repair to ordering and stock parts. Couldn't even depend on the boss to do his job. He was more interested the girls and the booze.
biggertv
Clutching Idler? If so it has a Spring and springs wear out. Especially newer ones. Steel ain't what it used to be, It may not be giving the stretched belt the tension it needs, possibly slipping at Transmission under load. For Fluid Change, I'd use a hand pump. You may have to get creative with hoses, tubing and clamps to make a small enough hose to fit the tranny. remove as much as you can, add a quart and remove all that. Then Refill. Good Luck! Need cheap tools? Some Harbor Freight sockets and wrenches are Much Better than they were 20 years ago. I like the colored sockets. Not Snap-On, but plenty good enough for sub-Space Shuttle Level work.
Oldaarpy
Thanks for the replies. New clutching idler came today and when I went to put it on not only was it in the wrong place but the sides were smoother than the new one. I've never messed with the idlers that I can think of so I think it was assembled wrong. It's raining again so my test drive up the hill was short but it seemed stronger. I may yet have to have the oil changed.
At my age I don't need expensive tools nor can I afford them. The only problem I've had with HF is there bolts and screws are chintzy.
I saw the drain plug. Can it be reused or require a new one? Anything else need to be purchased besides oil? Looks like a major operation taking off the gas tank to get to the tranny. (I'm trying to talk myself into changing the oil myself).
I don't think I'd want a spring any stronger.
Oldaarpy
Contacted TuffTorq to see what I needed (exactly) to change the oil and filter. They replied the filter is NOT a servicable item and all I needed was drain plug seals and fluid. In the mean time, on a real hot day, the mower refused to go up a hill with the blades engaged and made a grinding noise, but was fine when not under the stain of mowing. I'm hoping changing the oil does the trick but the seals are on back-order.
