Greetings all,
I recently picked up a LT1042,circa 2006. The engine is a 19 HP Kohlor Courage. I thought it had a small oil leak, but the valve cover gasket was blown. I wish I had found more about this prior to buying it. I still would have bought it but not for the price.
Anyway, this weekend I repaired what I think was wrong, but haven't been able to try it out yet. If the weather holds I will tonight. I guess you could say I don't have a current issue, but was wondering what I should be looking for or maintenance to plan. I checked the slack in the valves and they seemed ok. Oil is fresh, not sure about the filter and it has 223 hrs on it. The model number is 13AX11CG710 and the engine is a SV590S.
Suggestions, comments, constructive criticisms are welcome. I've attached some pics. OR will be shortly.
GT
GT
