what about this one? https://www.harborfreight.com/750-lb-heavy-duty-atvmower-high-lift-jack-63298.html $249. I use one of their ATV lifts for some small car engines and it has served me well.
Zoom in and you’ll see a hook grabbing the front edge of the deck.Is this the one being talked about ? ? ?
Not seeing where its lifting by the deck.
It is a expensive little devil though...
I use the first one on my Craftsman tractor and my Toro zero turn. I stick metal pins through the holes in case the hydraulics lets out. I also place jack stands under it.
