Jungle Jack Vs MoJack Pro
ottoslanding
:banana:
Which one?
:drool:
Pros and cons?
:confused2:
Experiences?
:dance1:
Thanks in advance
:thumbsup:
Mad Mackie
Hi ottoslanding,
You are comparing two very different jacks. The Jungle Jack is a typical flip up type unit that grabs somewhere on the front of the deck or frame and the Mojack Pro picks up by the front tires, is adjustable and has a winch. I have a Mojack Pro which is used primarily for cleaning my Hustler X-ONE rear discharge machine.
Mad Mackie in CT
djdicetn
Hi ottoslanding,
Mad Mackie in CT
Anyone own(can post a picture of) the Jungle Jack so we can see the differences??
P.S.
User lawn mower fanatic.....if you happen upon this thread can you move it to the General Mower Discussion forum(since it ain't exactly Scag-specific:0)
P.S.
I moved the thread to the General Mower Discussion Forum. :smile:
Jungle Jack
Lift Any Mower From Any Angle
"The new and improved single lifting hook on the Jungle Jack makes it easier to lift your equipment approximately 19 off the ground from any angle. It will lift virtually all belt drive and hydro walk-behinds in any size or model. It will also lift any ZTR or stand-on-mower. The Jungle Jack has a lifting capacity of 800 pounds. The large foot assist pedal on the Jungle Jack helps the operator lift the mower with the use of their legs, taking the pressure off the operator痴 back and arms. Jungle Jim痴 also offers a wider tooth, which enables the user to lift mowers with wider decks."
Jungle Jim's Accessory Products | Jacks | Jungle Jack
jungle jack 1.jpg jungle jack 2.jpg jungle jack 3.jpg jungle jack 4.jpg jungle jack 5.jpg
djdicetn
Jungle Jack
View attachment 17324 View attachment 17325 View attachment 17326 View attachment 17327 View attachment 17328
For some reason, after looking at the pictures of the Jungle Jack....I'm not certain I would have a warm & fuzzy feeling about crawling underneath my Gravely with it lifted up with that design versus the MoJack:0(
I agree....and the little hook that keeps the mower up almost looks like the one that is used on the push mower lift.....a push mower is a LOT lighter.
MoJack Push Mower Lift Lawn Mower Jacks-The MoJack
exotion
I own a jungle jack and it has a locking lever keeps it from tipping. I actually love the thing takes up nearly no space and its easy to use. You could even lift a car with it (I lifted a corner of my jeep cherokee)
ottoslanding
The Jungle Jack was recommended by my scag dealer. It is the only thing they use in their service dept. They do not recommend the Mojack.
It is a long time dealer and they sell a ton of Scags and Jungle Jacks
Brucebotti
I would also look at this one from Harbor Freight. Right now its on sale for $79.99 and I was able to use a 20% off coupon. I looked at the Mojack (the lighter duty one - 300#), and the HF unit is of equal quality. I've used it several times and it is pretty sturdy. Like all Harbor Freight equipment, it is great for the homeowner. It would not likely stand up to being used in a shop everyday.
Bruce
High Lift Riding Mower / ATV Jack
