nettieabcd
- May 23, 2012
- 1
- 3
Hi there,
I have an older JD LX 188 that has been a wonderful machine until recently. What happens is that it starts and runs great until I start mowing. Then after about 5 minutes it starts to mis-fire and eventually stalls. It will sart again fully choked but then go only about 10 feet before stalling again. I have replaced the spark plugs, installed a new carberautor, cleaned the fuel lines, checked the fuel pump, 2 mechanics have looked at and it still does the same thing. It will run just fine until it is under a load, a feature of the problem that I can't get the mechanics to understand. Could it be coil/wires?
thanks for you help.
