- Nov 29, 2014
- 65
- 24,995
Correct pump ?
Your engine uses an impulse pump and they are all interchangable.
Check you have it plumed properly.
The top hole is for the impulse line from your engine
the tube nearest it is the intake and the one on the opposite side is the outlet.
There is a check valve in the outlet so if it is backwards it will not work.
Now IF you are willing to do what is asked we might be able to fix your problem.
OTOH if you are determined to race out and replace parts willy nilly I will go somewhere that I can be more helpful.
You said the carb is not getting fuel, 'How did you come to that conclusion ?
Are you sure that the fuel is being delivered from the fuel tank ?
Dose this model have twin tanks ?
If yes is the tank turned on ?
If it is a single tank, can you siphon fuel from it ?
If not try blowing back through the fuel line and see if it makes any difference.
Have you tested the fuel system as I previously asked ?
