smalltowntex
- Jun 18, 2019
- 1
- 10
Whoever it may help. I had a thread on another forum. It has closed but maybe this will help someone.
John Deere XX324 I bought new. Run pretty good for a few years then one season it died while cutting grass. In a few minutes it fired back up like nothing ever happened. Didn't happen again the rest of the season. (this has been going on for a while) Next year it started in again only more often. Probably did it 7-8 times thru season. I would just let it cool down and everything was fine, at least for a while. Next season last year it was a PITA. Happened rather frequent. Always considered myself pretty handy but never tried to make a living at it. Worked and piddled with it and finally took it to John Deere. They milked me for all it was worth and then told me it was fixed. They didn't do anything...they just said it was fixed. I didn't make 2 rounds and it did it again. I did everything under the sun. ELectric fuel pump, new gas lines, carb solenoid, )no new igniter module though) and you name it , I did it.
It was not running out of gas, it was losing spark.
I will spare you fellows the rest of the story but you get the idea. I got to looking here and there with my gee whiz circuit tester and it all led me to a little black box up by the hour meter.
My problem all along was the "electronic control unit". They "say" this can go bad when you jump start (I never did) and one reason after another. It is always something else, not their faulty design.
So, a $100 later I am out on the yard again wearing an IPANA smile you wouldn't believe. It is a good feeling when you beat the system, stay out of the pro's repair shop, and manage to fix it yourself.
I just wish I had tinkered and seen the little black box earlier.
I hope this helps someone. Nothing like a little help along the way.
smalltowntex
smalltowntex
