John Deere s100
If you have a rectangular hole under the front of the seat with a slider that goes up & down to show the fuel level the usual culprit is the plastic bracket the fuel tank sits on
You will have to remove both rear wheels to get to it
Some times the spring stretches but usually the bracket breaks off on the right side where it bolts to the frame.
