After several months of looking at reviews from different mowers purchased by others, we ended up buying a John Deere D160 48" lawn tractor. All brands have quality issues, some woefully so.
This mower was ordered from a local JD dealer. If you buy from a big box store, makes no difference. The quality of the unit remains the same. The reason we went with the dealer was to support the phony local economy. But after this experience, I would have risked renting a U-haul trailer, went to Lowes, and dragged the
machine home myself.
Paid around $2800 for the machine, not really needing one that big, but trying to buy up in quality, which is futile.
The first thing you are going to have to do, is take the tractor apart. Why? because it will be delivered to you having quality issues not covered by their warranty and need to be corrected before the first mow, or you will be stranded, broke down in the field, and expensive. This mainly has to do with the front axle/wheel bushings having been greased using the best grease you can find.The other issue is the mower spindles and the grease used there as well. The company uses general purpose grease - in my case, two different colors, both the red and tan. perfectly good grease for toys, but not for a dangerous device such s a lawnmower.
John Deere is expecting you to have a tool box as the first thing the consumer is to do is adjust the guage wheels. 15mm bolts. self locking nuts. Miserable using ajustable wrench and pliers.
We will quit now. If interested we will start a new thread John Deere repair in another part of the forum to elaborate more.
