Started by only clicking when key turned key to start. After turning key to start 10-15 times (clicking each time) it would start. Now it will not click or start. All s/switches check good.
Appears to be the ignition module (with key). But this part is no longer available from JD. Is there a way to work around this? What should I try next? Fuses are good. Battery is good with full charge. Cleaned battery cables, removed and cleaned ground to frame.
