john deere lt166 wont start turns over but not starting
debsav
  • / john deere lt166 wont start turns over but not starting
john Deere lt166 wont start turns over but not starting. I replaced the spark plug and but teaspoon of gas in spark plug hole did not start.
reynoldston
you need to test for spark other then just replacing the spark plug.
Fish
Find the model numbers off of the engine and post them for help, thanks
davbell22602
I have JD LT166 46in with the 16hp vtwin briggs.
debsav
I checked for a spark this evening and there appears to be none. Now what do I do?
debsav
There was no spark so I looked for a wiring problem and found a connector that was popped out of its hole. i pushed it back in and then tried it again and it started. pretty simple fix. The wire must have been shorting out on the metal.
Thanks for your help.
