Good morning Ken,
Late hours again yesterday but blessed to have a job. To answer your question, I was checking the voltage at the pigtail that comes from the new wiring harness to the PTO clutch. The yellow wire terminates in a crimped terminal on one side of the pigtail and the two black wires terminate in a crimped connector on the other side of the pigtail. There is a plastic divider between the two. I touched the black probe of my meter on the terminal with the black wires and the red probe on the terminal with the yellow wires. The connector is very clean because it's brand new and hasn't been used in a grass cutting mode yet unfortunately. A quick question on checking the resistance of the coil. Forgive my ignorance but I'm assuming the coil you refer to is the part onto which the pigtail plugs? If so, I'm also then assuming I follow the same basic procedure (ignition on, switch on, probes touching the respective negative and positive sides of the coil)? Sorry to be dense on this topic. As always, thanks for your time and help.
Frank
