John Deere L120 With Briggs 20hp V-twin
mechanizm
ok, i had the carb-float stick closed on me so i got that fixed. i fired it up and it ran good until i idled it down and back up. the funky mechanism that controls the rpm is not allowing the butterfly to open properly and it starts running super-rich and chugging badly. i can open the carb butterfly by hand and it tachs up well but i just can't control it from the cable. i had this problem long ago and fixed it but now my brain isn't working. if i remember correctly the throttle linkage needed lubrication because it was sticking. i may slather it with D40 tomorrow. is there an easy way to circumvent that maddening and complex idle-up / down and just hook the cable directly to the carb butterfly?
THANKS!
Boobala
THANKS!
YOU failed to list your engine model numbers, not sure if this is the CORRECT manual but you can check it out and see the chapters on linkages
https://docs.google.com/file/d/0B6NaqjIxWV1ySkZjTTA5TGltZEE/edit
GET INFO.JPG ......NEXT TIME ...!!
mechanizm
ok, thanks, i'll check it out and will look for an engine # tomorrow. i had this prob before but i can't remember how i fixed it. i THINK that i just lubricated the mechanism. maybe i forgot a spring....
mechanizm
that looks like the engine/carb. when i throttle-up it bogs and barely runs. i can manually hold the throttle rod open and it idles up fine.
BlazNT
WD40 is not a lubricant. Use spray white lithium grease. I put the straw at one end of the cable then tape it very tightly and spray till it comes out the other end. Then move the cable a couple times till it moves freely.
mechanizm
will do.... thanks! it's raining like a biblical prophecy here in florida so i'll have to wait until it clears. but will buy the white lith today.
mechanizm
just to be clear: it's not the throttle cable that's the problem. it's the spring mechanism below that that's causing problems and i don't understand how it works.
is there a process to remove all of that spring-loaded nonsense and just run the throttle cable to the carb butterfly?
The thing you are having trouble with is the governor.
The governor slows the engine down by closing the throttle ( which from here on in I will call the butterfly to avoid confusion )
How much it closes the butterfly is determined by how fast the engine is spinning.
The faster the engine spins, the harder it closes down the butterfly,
Working against it is the lever you move which I will call the throttle.
The governor and the throttle are connected together by a spring, called the governor spring and the strength of this spring determines how fast the engine spins.
Inside the engine are some bob weights which rotate a shaft as centrifugal force causes them to be flung out.
The shaft , called a governor shaft pokes out of the engine .
the governor arm is clamped onto this shaft.
SO the shaft moves which moves the lever with moves the wire rod which moves the butterfly.
Google Taryl fixes all - governor .
That should bring up afew videos which will explain exactly how it works and how you adjust it.
If it is broken then you risk major engine damage by continuing to use the engine.
The governor will alter the engine speed about 20 times a minute to keep the engine spinning at the most powerful speed and you have no chance of doing the same by hand
mechanizm
that's what i needed to know. googling now. THANKS!
BUT, i think that you can eliminate that governor assembly and just use common sense when idling-up and get a tachometer to keep from over-revving. these governors are problematic
mechanizm
ok, i've looked at the governor mechanism and everything is moving freely. i can start it up, idle it up but when i change throttle the governor acts up. i can move the butterfly valve in the carb by hand and then the governor starts working properly but i can't change the engine speed or it will go back to chugging. all i did was fix a stuck float bowl and now this...
