John Deere Kawasaki 22HP water cooled
Spiderweb
Dash charge indicator lamp stays on ,but Battery stays charged?
mechanic mark
check connections for a good ground by hand, make sure everything is tight & secure.
Hammermechanicman
Measure battery voltage with tractor off. Then measure battery voltage with tractor running at least half throttle.
I reckon an update over 2 yrs later is better than none.
