Dash charge indicator lamp stays on ,but Battery stays charged?
S Spiderweb Member Joined May 30, 2020 Threads 6 Messages 13 May 30, 2020 / John Deere Kawasaki 22HP water cooled #1 Dash charge indicator lamp stays on ,but Battery stays charged?
M mechanic mark Lawn Pro Joined Jul 15, 2013 Threads 175 Messages 7,413 May 30, 2020 / John Deere Kawasaki 22HP water cooled #2 check connections for a good ground by hand, make sure everything is tight & secure.
Hammermechanicman Lawn Addict Joined Jan 10, 2020 Threads 55 Messages 3,526 May 30, 2020 / John Deere Kawasaki 22HP water cooled #3 Measure battery voltage with tractor off. Then measure battery voltage with tractor running at least half throttle.
S Spiderweb Member Joined May 30, 2020 Threads 6 Messages 13 Nov 27, 2022 / John Deere Kawasaki 22HP water cooled #4 Replaced bad Volt regulator.
StarTech Lawn Royalty Top Poster Of Month Joined Feb 19, 2020 Threads 79 Messages 10,264 Nov 28, 2022 / John Deere Kawasaki 22HP water cooled #5 I reckon an update over 2 yrs later is better than none.
