I don't know much about lawn mowers but today I started mine up and it was running okay and then I noticed the engine sounded very weak. I stopped it and went to take a look and made sure nothing was stuck under the blades. There wasn't anything so I attempted to start it back up but the cord wouldn't budge. I started taking the thing apart while looking online for fixes. I removed the rewind pulley part and when it's disconnected from the rest of the lawnmower the thing works just fine, I can pull it all the way.
Again I don't know much of lawnmower jargon, but when I put the pulley parts back on the lawnmower, the thing that houses the center of the pulley thing and try to pull it, it wont budge. To the best of my knowledge what appears to be wrong is the white ratchet balls(?heard it in a video), the things that are in the pulley are getting stuck in the center part. I don't know if that makes any sense. Any help would be appreciated!
