cdeno0001
- Apr 17, 2020
- 1
- 4
Hello. I've had some time off due to good ol' Covid and worked on my Dads mower. It had sat for probably 2 yrs. I did a lot of reading and suspected the cam was shot, howerever I initially got it running because the valves were so out of adjustment it wouldn't start. I got it running and used it for a few weeks with it working fine. The other day I was mowing and it cut out and stumbled like it was out of gas. It shut off in the middle of the field. Today I pushed it over towards the garage. I pulled the plug and confirmed it is getting spark. (it also blew fluid out of the cylinder from where I sprayed something in it to see if it would fire earlier.) Next I suspected a clogged filter, I pulled the hose off the carb and changed the engine and it was pumping fuel out the hose. I pulled the carb and cleaned it the best I could, it didn't appear to be really dirty. I put it back together and still won't fire. I haven't pulled the valve cover back off to look at the valve train yet because it started raining.
It seems to be getting fuel and spark, but no fire whatsoever. Idk. any thoughts?
