sardonicus
- Aug 26, 2021
- 3
I've got one of these mowers with about 190 hours on it and just recently it started acting very strange. It's had regular maintenance and all that. It will start and run but it doesnt idle at the rpm that it usually does. If you engage the blades it bogs down considerably and doesnt reach cutting speeds until they've been running for several seconds. It also acts like its under a considerable load just moving itself around without the blades engaged. So my question is what would cause the mower to act as though its under a serious load at all times.
