I have combed over the JD manual. It shows an F1 Fusible link in the schematic just before the starting motor. Does this mean there is supposed to be a fuse there which I can check? Because I cannot find any fuses there, Just wires that join together in a protective jacket. Or when it says, "Fusible link", does that just imply a some type of connection of wires but no fuse there?
