reynoldston
- May 23, 2011
- 92
- 5,705
That is true but, since I dont have a tester I was just checking to see if there was any spark at all and both plugs have a spark and even if one of them was weak it should still fire on the other cylinder or at least pop but, it does nothing.
I have seen something on this forum, never assume anything when it comes to electrical. Two bad spark plugs?? I don't care what engine you have, you need fuel, spark, compression, timing and it will run. Seeing it was running good up till now I would be checking more into the fuel part of it. Spark plugs are cheap so just put two of them in and also a new fuel filter. Start small.
