John Deer D100 blue smoke when it gets warm
88m5
I am working on a JD D100 put new carburetor ,battery and did a oil change on the mower starts up fine and cuts great after about 15 minutes blue smoke starts coming out the exhaust and then it quits. If i let is sit for 15-20 minutes i can start it up again and runs great for about 15 minutes and then the blue smoke and it quits.
Any suggestions on where I need to start troubleshooting?
Thanks
CA
Being a Briggs single cylinder intek engine I would suspect that you are at the beginning of a failing head gasket. Head gasket will burn through the area between the cylinder wall and the push rod cavity.
Hello Ilengine,
I concur, the head gasket is on the way to full failure mode.
Blue smoke is oil.
I hope she is not over heating.
Pull the oil dip stick and smell for gas. If you smell gas your carb needle/seat needs some love.
Check torque on head bolts.
Most likely as ILENGINE and Auto Doc's said, probably head gasket time.
If you want to permanently fix a head gasket on this particular engine, you need a solid copper gasket. If you do a search on here a while back, think Bertsmobile1 found a guy that makes solid copper gaskets for reasonable prices. Search for Intek and blown head gaskets.
Here is one shop that sells copper gaskets. Don't know if this is the one I was talking about. I think if you tell these people you have a Briggs blah blah Intek, they can make you one??. Worth a free phone call. Click the link below where it says lawn, minibike and kart in green font.
Everyone
Thanks I will pulled the shroud and check everything I do like the idea of a copper head gasket
