puddleglum
I’m trying to fix up some old equipment and am currently working on an MTD Yard Machine lawn tractor, model 13AK608G062, from 2000 I believe, with the single speed transmission. It needed a new lower belt, so I replaced that with an OEM belt. It moves now, but not smoothly. I may go along nicely for a few seconds, then the the machine starts to move in spurts, starting and stopping. The variable drive pulley is in good shape, smooth and turning easily. The engine runs nice and smooth. The drive pedal adjustment is okay—the tractor does not move when the pedal is released. There doesn’t seem to be anything else to check with the belt. Could this be a transmission problem? If so, what should I be looking for?
