First off…I will not answer the first question just in case she ever comes across this thread.You said your wife does most of the mowing. Congrats on that. Anywhoo, I was wondering is she a petite gal at 92lbs or a healthy girl? Wondering if she is lifting out of the seat causing the seat switch to open up killing the coil/s? Hitting bumps......
Next thought was check all safety switches and wiring. Clean/polish all connections and goop some dielectric grease where possible. Play around with the switch plungers and a multi-meter. Barely push in numerous times then give it the full gundy several times. Go to the next switch. Could be a bad wire too. Old mower, might be time to rewire all the switches.
