Got a tricky one. Need thoughts. Deere 375R. 25hp Briggs. Was surging and dying after ~ 1.5-2 hours of mowing. After carb work, ended up replacing with OEM carb. Removed and cleaned fuel tank. Blew out all fuel lines. Replaced fuel line from fuel tank to carb. Replaced fuel filter and fuel pump. Replaced both ignition coils. All to no avail. Brought to JD dealer and they ran it several times for extended amounts of time and tested under load in thick grass and it never missed a beat. Took it home and 20 minutes into mowing, started surging and dying again. Thought maybe bad gas, but I’m running our 355E on the same gas without issues. So both I and the mechanics at the JD dealer are stumped. Insight appreciated.
Jim
Jim
