tsmurphygirl
- Dec 7, 2015
- 1
- 3
Just took our JD in to the shop 4 months ago to have a throttle valve replaced to the tune of $600 when all said and done. Recently, this mower started blowing white smoke from both the engine and muffler after running for awhile. It starts out a little at first, then gradually smokes more....no noticeable engine loss or problems other than the smoke. When I first noticed it, I could see oil slowly dripping on the muffler, causing the smoking there. There is dirt/oil buildup between the muffler and engine block, but when I cleaned it off and ran again, looking for leaks, I didn't see any, not even on the muffler like before. I plan on changing oil, fuel/fuel filter, and spark plugs first, but does anyone else have experience or suggestions that a moderate diy'er can do? Trying to keep it out of the shop again if possible....Thank you in advance
*please see lower post w/pics showing oil leak out valve cover and inside after sitting
Engine Model: 44L7 77 0134 G5
23 HP 724cc
JD Turfguard 10w-30 oil
23 HP 724cc
