BashRipRock
Hey guys. I have been helped several times on here. I've got something I have never encountered before. I got this mower at the beginning of the season. I kind of just got it from a guy of a guy kind of deal. Runs great. I put on new deck belt, new PTO switch, new blades, new muffler, and some missing fasteners. I finally got the mower leveled and mowing well about a month ago. No issues. Until my last 2 mowings. I have a small backyard. I used to mow it with a JD Walk Behind until I got this unit. I mow in 1st gear. The last 2 times when I would start mowing I would look back and some of the grass mainly in the middle of the deck was cut some, but more liked pushed over. It only does it when I enter into the grass. It measures about 5ft in length, maybe less where this happens then everything is fine. When I get to the end and turn into another piece of grass it will do it again. Throttle is running at full speed. The only thing that I notice is it seems like the blades aren't turning fast enough? Belts are in proper tension, everything is turning freely etc. So it leaves me to go back over those spots in the opposite direction the mower takes care of it. I am sure if a plane were to fly over which happens often probably thinks I'm drunk or crazy. I don't mind going over it again because my yard is so small, but would like to get it figured out. Any assistance or suggestions will be greatly appreciated. Thanks in advance!!!!!
