Hope this isn’t too much information, but it seems like multiple issues have happened at once. I’m new to riding mowers and at a loss. Has been running ok-ish, bought used just 2 months ago to cut about 1/4 acre lawn every week. Don't know how old it is but ID pic attached.
Mowing last week noticed the engine intermittently sputtering. There are bumpy spots in the lawn, and sometimes when my butt leaves the seat, it sputters because of the safety cutoff. But this happened on flat spots. I always mow in late afternoon so the grass is dry.
Today I just finished 30 minutes of mowing, it sputtered again on the bumpy spots but also on flat spots - again - where the seat wasn’t even jiggling, and 2 times, cut off completely like fuel starvation, when I was barely rolling. But it would start again.
After I (luckily) finished mowing, I tilted it on one side about 12” in the driveway and scraped all caked on clippings from under the deck. I lifted the seat and carefully examined the wires for something loose, but nada.
Afterwards it wouldn’t turn over at all, now theres only a very soft almost inaudible click.
And for some reason, now it won’t shift out of neutral or roll
Checked the obvious things
- park brake is disengaged (or engaged no difference)
- half tank of gas
- fuel filter is clean
- new gas
- the blade drive lever is not engaged
- transmission shift lever is in neutral
- seat is completely down
- depressing foot pedal/brake/clutch or not makes no difference
It has a brand new Apr.’21 battery but I cleaned the terminals and cables, and put my trickle charger on, which shows a full charge.
The headlight doesnt come on but I never noticed if it worked before.
I have the manual and under “Engine clicks" and "will not turn over”, I did the things I know how to do.
But I wondering if anything obvious comes to mind.. because the 2 issues - sputters/won’t start and won’t roll are related? Could it be the “operator presence” safety switch on the seat? Fuses? Spark plug?
I don’t have a truck or trailer so getting it hauled to a repair shop 30 mi. away will be a majorly expensive undertaking…
- half tank of gas
- new gas
