JD LA165 Need Suggestions Of Upgrades
Camaron32
This year I plan on upgrading my 2007 LA165. I know the wheel bearings can be replaced with actual bearings. Can the steering column and front wheel spindles be upgraded with bearings? What upgraded have you done? Any suggestions are greatly appreciated.
The only upgrade to the LA wheels that I have found to work is the use of the full length Toro caster wheel rollers .
everything else has failed myserably .
