JDgreen
- May 14, 2010
- 2,887
My 4210 with 60-inch 7-Iron MMM has always done poorly at chopping grass clippings up, even with very sharp blades. Posted my issue on TBN, and some members there advised me to buy JD Gator blades, or a comparable Oregon blade, telling me clippings would be much finer. Well, after the first 30 mowing hours this year, mostly with wet or damp grass, using a set of sharp OEM JD blades, I removed the OEM set, powerwashed off about 20 pounds of grass build up on the deck, and installed the Gator blades.
Result is...almost no improvement in cutting up dry grass, maybe 10-15% reduction in clipping size....and NO IMPROVEMENT in cutting high and/or wet grass at all. I had hoped to reduce all the raking I have to do of grass clippings, because it takes several hours per week alone to rake everything up. No matter how often I chop up the clippings, they will not break down and leave unsightly windrows all over my lawn.
No matter how high I cut the grass, or if I just do half a deck width at a time, and even running the engine at PTO speed (2600 rpm) while mowing....NO IMPROVEMENT.
Any ideas? Thanks.
Any ideas? Thanks.
