JD 777 stopped and won't start
KKuhl
Hello, was mowing with JD 777 zero turn. Engine just stopped after mowing about 30 minutes. Cranks and has fire, but will not start.
hlw49
Did you check the oil before you started mowing and is it now full of oil.
KKuhl
Has fuel and oil
hlw49
Try spraying some Gum Out carb cleaner in the throat of the carb. Could you have water in the fuel?
Bertrrr
Just because it has a full tank don't mean it's getting to the Carb / engine intake ......start from there and work backwards
KKuhl
New fuel. Pulled line off above fuel pump just below carb. Steady stream of fuel coming from there. Checked compression. Left side has 140 and right side has 145. Engine has about 930 hours on it
Bertrrr
Well , for an engine to run has to have
1 - Fuel
2- Compression
3- Fire
4- Timing
Go down the list and see what's missing ,
Did you happen to hit something ? it can shear the flywheel key a bit and that's all it takes for your timing to be off and it aint running for anyone ...
