Ron_P
 - Jul 3, 2016
- Threads
 - 6
 - 21
I have an older JD 345 with the 20hp liquid cooled Kawaski V twin. In the past it would die after running for a short time. Then refuse to start until left sit for about an hour or so. Once it starts again it's fine, might not die again until I mow next time. Well today wife was mowing and decided to take a break. The thing ran fine for well over 2 hrs. She parked it under a shade tree. About 2 hrs later she went to finish mowing and it would not start. Cranked fine, has plenty of gas. I tried pouring a small amount of gas into the carb, but still would not start. Here's what puzzled me.
I pulled the left plug wire off to check for spark. I had wife hit the key, and it started to fire. I put the plug wire back on the spark plug, died. I had to pull it off, hold it slightly off the spark plug, and it would fire and start. Finally it did start and run. So I'm curious, why is it doing this? Spark plugs new, good fuel, new fuel filter. I've never had an engine start by removing a plug wire.
Could it be the coil is going bad? It seems to me to be an electrical problem, not a fuel. Any insight is greatly appreciated.
