Jack points on Z3x
Hoosier70
I am a new user of the Ferris Z3x (61inch). I recently damaged a rear tire but am not really sure where to jack it up at...since the tire is flat i cant get my trolley jack under the rear. are the fenders acceptable jack points? i saw someone on you tube with jack stands under them...doesnt seem wise to me but...
Use a bar over a brick or two to lever it up high enough to get the jack under
A second set of hands can be quite helpful
Do not put a jack under anything other than the frame
