jpalmer1717
I have a 11.5hp manual pull Swisher pull behind. Briggs. It will only run using carb spray. So I bought a brand new carb, installed all new fuel line, and that didn't change a thing. I still feel like this is a fuel issue. But I do see fuel filling the clear filter, and the carb bowl is always full when I check it. I've noticed that while I keep it running with carb spray, I don't see fuel moving through the filter. I'm not sure if it would be obvious or not. So pulling the rope fills the carb, but maybe nothing continues to pump it? I just don't know. What in the heck is happening??
