flymo.mulch
- Oct 7, 2015
- 0
- 11
We're flying! Got it all back together, and it started on the 4th pull! Runs OK, and doesn't seem to bog down or anything, but it just from the sound it feels like the mixture isn't exactly right. Unfortunately, the idle jet adjustment makes little difference, and as mentioned, the main jet is fixed, so there's not much to try there.
I ran it with the snorkel air filter in place, but not the foam one right in front of the carb. The remains of an old foam filter were in there when I bought the unit, and I did get the foam element, so maybe that's the next thing - oil up that element and see if running a bit richer helps. I guess I could simulate that with partial choke - maybe I'll give that a try.
As far as I can tell with just a few minutes of time on it, Flymo mows reasonably well. It seems to have less resistance to moving side to side than it does going forward and back, so you need to make a conscious effort to keep on track. One really nice thing is that the whole mower is very light, I am storing it just hanging on the wall like a rake.
F
F
