Bearrepair
- Mar 24, 2024
- 4
- 17
Ok so to start with this i figured the pto switch was bad i took multi meter to it and was not getting complete connectivity through the prongs when pto would be engaged so i ordered a new one. I installed it and still didnt work so i went through checked all the safety switches and all were operating normally so i pulled the new switch and found it had one set of prongs that did not work when engaged so i returned it and got a new one. When i installed the newest switch and attempted this resister or fuse that is connected to the terminals in the wire connector going to the pto burned and split. Now the pto reads 2.9 ohms whitch i thought was good for pto so what are my options anyone have an idea what might have caused this maybe im missing something. I have the 20hp vanguard on this model including in the pictures is the simplicity model designation.
