- Nov 29, 2014
- 65
- 24,995
We are a church and have had the exact same thing with the IS700Z. The dealer has brought it back to the shop twice, the Ferris rep has come out and said there was nothing we were doing wrong. We have been through 6 belts in 120 hours of operation.
I can understand the belt popping off the pullies from debris getting onto the deck but the belts are snapping or tearing with no rub marks on them.
We are extremely frustrated. The dealer is out of suggestions and we are at the stage of talking to the Ferris rep about a full refund.
if anyone has found a solution I would love to hear it.
Belts only snap cleanly if an extreme shock load is applied and the belt is too tight and can not slip on the pulleys.
Generally the big belts on mowers with electric clutches are plain belts which when they get hot , get sticky and thus do not slip very well.
If the belts that are breaking are plain, not wrapped then you can try fitting a wrapped belt.
You can also go to a kevlar fiber belt but in sizes over 100 inches wrapped kevlar reinforced belts become very expensive .
you can go to the Gates belt locator and type in the part number.
If Gates make a similar belt it will appear and then if you click on the belt number you will get the belt dimensions so you can then find replacement belts.
In the mean time back off the belt tension a bit and have a good look at the blades for evidence of striking hard things like gutters when moving from car parks to grassed areas.
Forun choked when I tried to post the url so google "Gates belt interchange" and you should be able to find the page
Or try putting the "w" in front of this .gates.com/all-search-tools/automotive-interchange-search-results
