HusqvarnaRider
Rev,.... Shouldn't it be called "Perpetual Combustion", since it continued to operate without a "Spark"?Called pre-ignition. A hot bit of carbon, a sliver of metal that is hot enough to ignite fuel vapor. https://en.m.wikipedia.org/wiki/Pre-ignition
This is what separates mechanics from on-lookers.
And I'm actually familiar with it somewhat, as in the case of an Oil Burning Furnace, where the Oil Gun, pumped far above the normal amount of oil, in to the Combustion Chamber, but the Thermostat had shut down the "Gun". The "Refractory" in the Combustion Chamber was still hot enough to ignite the oil, which in turn, as the temperature rose, it activated the Blower. That action causes all kinds of Problems, ranging from Soot/Carbon Buildup in the heat-exchanger, to blowing the Oil Gun out of the Furnace, & Causing a Fire.
I'm not claiming to be a "Lawn Mower Mechanic", but I do understand "Combustion" due to my work in HVAC.
