Is simplicity a good zero turn mower
flasks
I've been looking at a Simplicity zero turn with 60" cut. It is 5 years old and has 42 hours on it's twin cylinder engine. It also has independent suspension on all drive wheels. It appears to be in excellent condition through-out. It also has running lights, has been serviced regularly with no appreciable wear on the tires, it starts instantly and has been stored inside when not it use. The blades show moderate wear and I was told these are the original blades. Owners asking price is $5,500. The model is "Stallion" and while researching on the web I learned that this zero turn mower is no longer made so would replacement parts be available? At the prices I see for other zero turns with low hours in this condition this Simplicity for sale is a bargain. Your opinion guys??? Thanks, Flasks
