bgarfinkel
- Oct 21, 2013
- 4
I was gifted a 6000 watt PowerMate generator that has a rusted fuel tank. I've seen home remedies to clear the rust out but I think it it too far gone including the fuel cap assembly.
The specific replacement gas tank is over $90. I've found other gas tanks that are similar capacity for less than $40.
With this specific generator I'm confident that I can mount the other fuel tank to the metal frame, so the physical fit is a non-issue.
Are all gas cans essentially created equal from a functionality standpoint?
If I replace the tank with one that fits another engine is there anything I should watch out for?
Thanks in advance.
Thanks in advance.
