Boobala
- Feb 15, 2015
- 7,000
Good afternoon All,
I'll need to track down some thicker gauge wire to create that ground strap for that 4th pole on the Solenoid, I'll try to get that handled this weekend.
Based on what I've been able to read-up on PTO (Power Take Off), it's normally a gear or rotor that transfers power from the engine to an attachment, and while I can picture that on any other tractor, I can't think of where such a thing is on my tractor, other than the mower deck, and that is pulley/belt driven, and activated/deactivated by a physical lever, so now I'm even more confused about the PTO being an actual switch.
Forgive my ignorance here, but what is a PTO SWITCH, and where would it come into play in my equation?
-David
Dave you only need a piece of 12 or 14 guage wire, for the extra solenoid "ground wire" .. I attached mine to my throttle bracket assy.
