- May 6, 2010
- 51
- 11,253
One thing that does not seem to have improved over the old engine is the position of the oil drain plug. I can see again when removing the plug lots of oil going over the mower chassis. Why not just extend it by a couple of inches to clear the chassis, well a couple of inches would make the difference on the Husqvarna.
The extended oil drain or quick drain systems, at least here in the USA are not supplied by the engine manufacturer, They are added by the mower manufacturer, and in some cases the just try to save a penny, and sometimes don't use anything past the factory engine drain plug. Oil everywhere is the norm, and if the customer wants it different then they pay for it after purchase. Some of the easy drain systems are not that good of quality, and have one in the shop right now that unscrewed from the block while running.
