Tinkerer200
- Mar 14, 2015
- 913
You are absolutely right, FOOT LBS.
Walt Conner
Walt Conner
As a machine shop owner, I recommend always checking ring end clearance as I described above. If there isn't enough clearance after starting the engine, the rings will grow in length and "may" experience abutment. If this takes place and tightens to the point of seizure, you'll have more problems that you do at this point. Always and I mean always check ring gap.
Always check to see if a ring compressor can collapse the ring entirely into the ring land. If the ring can't fit all the way into a new piston, either the ring land is too shallow, which very seldom is ever experienced, or the ring is the incorrect ring for the piston.
A replacement ring may have too much ring gap in mid stroke and at the bottom of the bore, however at the top dead center, it may look perfect. Check the ring gap at the bottom dead center, mid bore and top. If there the ring has cut into the cylinder, remove the material at the top of the bore until it is the same size bore diameter as the worn area of the cylinder bore. Then hone very lightly. You do NOT need a rough bore.
The reason you hone a cylinder is to hold the oil on the side of the bore for lubrication during break in.
Good luck.
