- Sep 24, 2017
- 288
- 6,901
Parts tree shows Briggs and stratton 3318773036 as the replacement for that engine, Shortblock is available for about $500-$570.
It will depend on your personal preference, how much $$$ you have, how much you like the mower you have and if you want another mower sitting around for parts or......in the way! You are you, we are not.....you have to decide!still cant decide.
$250 for a used engine
$600 for a new engine
$500 for a used lawn tractor that is comparable to the one I have.
the one I have has 450 hours on it, stored inside, before it went down it got new belts and blades sharpened.
Doesn't matter if the fuel shut-off is before or after the filteralright, so I got the engine in and it starts and runs.
1. I want to put a fuel cut off on the fuel line (gravity fed). Does the cut off go before the fuel filter or after the fuel filter?
2. there are some ethanol free gas place close to me. Is ethanol free gas worth the $1 more a gallon?
3. Will it eliminate gummed up carb problems?
4. does octane matter?
x2 on everything mowerking said.Doesn't matter if the fuel shut-off is before or after the filter
I wouldn't pay $1 more a gallon during the mowing season, not a bad idea for setting through winter though
87-91 Octane for mowers
