intek 12.5 hp engine cylinder head gasket need to confirm part #
steves snapper
Auto Doc's
Go to Google, then Part Tree or Pro Parts Direct and look up Briggs and Stratton using the numbers stamped into the valve cover.
steves snapper
273280S is the head gasket
I hate to give more for the exhaust gasket than the combined head an rocker arm gaskets.
I searched a little but didn't find the kit w/ all plus the intake thanks ILengine for explaining how to search
I'd like to have the set head/rocker/exhaust an intake but couldn't find it packaged together.
Briggs & Stratton 796189 gasSKET SET, Valve​
I didn't include a part number for the OHV valve gasket set because in most cases the only thing you will use will be the head gasket, and the exhaust gasket.. The gasket set doesn't include the O ring for the plastic intake manifold, just the paper gasket for the metal intake. Also most of the valve covers are using RTV and not the paper valve cover gasket. According to your date code your engine uses RTV and not the cover gasket
The head gasket list for 9.23
the OHV gasket which can be used but not standard on your engine 5.29
Intake gasket that don't fit your intake 2.66
intake valve stem seal 8.25
Secondary intake gasket that is not used with your engine 4.26
exhaust gasket 4.22
total individual parts $33.91
valve cover gasket set with all the parts included above $51.88
