That was a pretty decient whack you gave it there.
Should not be any problems with the engine as the dent would have been pushing the valves open against the valve spring.
Just have a close look to make sure the retaining collars on the valves have not popped off which is the only problem you are likely to have on the rocker box side.
On the other side there is a possability that the piston have have touched the valve head(s) and bent one of them.
This will be hard to diagnose without pulling the head off. The usual indication is that one or both of the valve clearences will be a lot bigger than it should be.
But as you say the valve lash is still withing specs you may have lucked this one in.
Start the engine without the valve cover on and watch the operation of the valves, if they are nice & regular pop a new cover on , refill the oil and go mow.
Thanks for all the advice! The springs, retaining collars, etc.. all look good visually, as near as I my novice eye could tell. To clarify one thing, I don't have a feeler gauge (ordered one on Amazon, coming in a few days) so I was just visually looking things. A few minutes ago I beat the old cover back into shape and reinstalled it to keep oil from going everywhere, then started it up as per your suggestion. It started and ran perfectly, at least as far as I could hear. Very reassuring! I'll run it again tomorrow outside with the cover off and observe the valves. Maybe I'll put the slow-mo video feature of my phone to use! :wink:
Do you think I should replace the exhaust side arm? It looks weird to me that the exhaust valve bolt head is offset a few mm down from being center with where it contacts the valve stem. If I push the arm up slightly it seems to be centered, but the intake / right side is dead on center without such fiddling. For all I know that is normal, but I'm wondering if maybe the arm got slightly tweaked. I placed an order for a new aluminum cover, gasket, bolts, and the arm assembly since it was only $4 USD. I'll install it and see if that fixes the centering issue. If so, I'll adjust the valve to spec and hope for the best.
If it doesn't fix the centering issue, then I guess that would lend evidence to the valve stem being bent. Like I said earlier though, I used my calipers to measure the distance of each valve stem to the top of the block and they seemed identical. I'm hoping that just means the arm or adjustment bolt is slightly tweaked rather than the valve stem.
